A/C Low Pressure Switch
Old Nov 13, 2005 | 05:53 PM
arizona98tj's Avatar
Default A/C Low Pressure Switch
Anyone shed some light on the A/C low pressure switch? The harness I have for it uses a 3 pin connector on it. All of the low pressure cylcling switches I have seen (on other vehicles) use a two wires.
I am doing a swap into a '01 Jeep Wrangler and this is about the last thing that is kicking my butt. Any help would be appreciated.
Old Nov 14, 2005 | 08:39 AM
I guess I should mention that the swtich in question is on the LS1 side of the harness.
Old Nov 14, 2005 | 11:29 AM
Mark IXZD 150's Avatar
I believe a 3-wire would be a 'trinary switch' which operates an electric fan along with the compressor. A two-wire would be a 'binary switch' and only operates the compressor.
Old Nov 17, 2005 | 11:02 PM
patrick_rodgers's Avatar
For a stock 2000 Camaro
pin a - sensor ground
pin b - 5v reference
pin c - pressure sensor signal
