ls1 help need measurements.
Bellhousing flange to:
- front of timing cover - 22"
- front of crank pulley - 26"
(this is fbody, Vette is 3/4" shorter)
- front of water pump - 28"
- front of throttle body - 24 1/2"
Center of crank to:
- bottom of fbody pan - 8"
- bottom of vette pan - 7 1/2"
- top of intake manifold - 16 1/2"
Overall width including exhaust manifolds - 26"
Deck height (crank to deck) - 9.250"
Head height (deck to valve cover) - 4.732"
Width of pan rails 10 1/2"
I've got a cad layout for the bellhousing bolt pattern if you're going to make an engine plate.
HTH
Perry
