Gas Pedal?
<img border="0" alt="[driving]" title="" src="graemlins/gr_driving3.gif" />
Try this pedal for your 55' BAG-6074
and this is the cable I am using TC-1000LS1
- Jeremy
67 LS1 Camaro project, Is there enough space between the engine and firewall for the gas pedal bracket to travel. On mine engine looks sit wery close and there is cables and hoses so I used the original cable mounted on the firewall like late model car by a washer welded to firewall.(I filed inside of a washer like the retaining clip of the cable) Inside the car I had a gas pedal from a 87 monte carlo, cut the end of it and welded to my gas pedal. But you have to mod. both litle bit to have full travel. Cable was long litle bit so I cut it and used cable stops.
