cooling an LS1 in a S-10???
Old Jan 24, 2003 | 08:47 PM
web's Avatar
web
Default cooling an LS1 in a S-10???
What would be my best bet for a radiator when using the LS-1? Does this motor require any thing special for hookups? I've already modified my radiator support as per the Jag's that run books in order to gain clearance. I also plan on funning two puller fans to handle moving the air. I've seen several radiator adds for s-10 swaps, but nothing specific for LS-1 apps.
Old Jan 25, 2003 | 02:58 PM
John B's Avatar
Moderator
Default Re: cooling an LS1 in a S-10???
I'm sure that any radiator used for a V-8 swap will be plenty.
Old Jan 25, 2003 | 07:49 PM
LS1 PWRD's Avatar
I can't speak for the S-10 but I'm using the stock 4.3 rad in my Astro with the fans from the LS1 and a custom built shroud for mounting. Never had a problem last summer with the system and the AC never worked better.
