LS1 into sonoma
Old Feb 15, 2003 | 08:54 PM
LQ4somona's Avatar
Default LS1 into sonoma
Putting an LS1 into a 96 sonoma 4x4. I will be using the C3 Seirra viscous drive transfercase, and the 4L65-e tranny. Where would I have to find motor mounts and stuff to get this swap to work. A stock Ls1 will go in for this year with a Big inch stroker being already put toghether for next year. <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> I just hope that the axles will hold together long engough for them to be upgraded <img border="0" alt="[bang head]" title="" src="graemlins/gr_banghead.gif" />
Old Feb 16, 2003 | 08:45 AM
LS1 PWRD's Avatar
Default Re: LS1 into sonoma
I don't know if anyone is making mounts for this particular swap as yet.
Making your own is not hard. I used 3/16" plate to make up mine in the Astro AWD. Had to modify the oil pan a bit and raise the engine. Also had to move the engine/transmission forward an 1 1/4" which meant I had to modify the driveshafts. In hind-sight if I had used the LS1 4L60E transmission (instead of the 4L60E in the Astro) I could have used the existing driveshafts. 95 and later 4L60E's are longer because of the different pump. Oh, well, we learn from our mistakes.
You could try Racecraft Conversions.Com and talk to Allan Hopkins. He's down to earth and knows what he is talking about. He also has a swap book he sells. There is also another site called Jags that run.
<small>[ February 16, 2003, 09:08 AM: Message edited by: LS1 PWRD ]</small>
