How did everyone do their gauges??
--Davey
95 Chevy K2500 Vette LS1, NV4500, Posi Lok
-Gordon
The oil pressure and speedo should work fine. We've hooked several up to GM clusters without a problem.
I do see a potential tach problem with your combination though, I'll look into that.
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
I have the circuit board mounted inside my dash. Normally, the guage galvanometers mount right into the circuit board. I took these out and mounted them to my stock guages. I have leads connecting the galv. pins back to the inst. panel circuit board.
I've definitely got the oil pressure guage working. It jumps about 30* of travel on startup and another 10* for a throttle blip.
BUT, I have no ODO (still wired to circuit board - planned to splice wire extensions to mount it on the dash). I have no tach, and I can't see anything happening with the voltmeter, temp guage or fuel level (I have an FBody sending unit and tank).
So, basically it is looking like I did a whole ***-load of work with nothing to show for it.
I'm not sure what to do. The guy I bought the cluster from said it was from a 2000 LS1 Fbody. My motor and PCM are 99. Should all work together.
