Lift Brackets
Old Apr 8, 2003 | 06:16 PM
Fastlane68's Avatar
Default Lift Brackets
Can anyone tell me what was used for lift brackets when lowering your engine into the engine bay? Mfr and P/N? Source? Where do they mount? Can they be mounted without disassembly of the intake manifold or acessories? My research tells me that GM left these out because the engine bay on F-Bodies were designed to lower the engine on removal. thanks - LM
Old Apr 8, 2003 | 07:09 PM
DaleMX's Avatar
Default Re: Lift Brackets
I pulled the manifold and used the accessory holes on the heads. Worked great. I was afraid of a chain touching and cracking the intake as it seems fragile. I've seen people use 2 towing straps, each wraped around the exhaust manifold and then to the hoist.
<small>[ April 08, 2003, 07:12 PM: Message edited by: DaleMX ]</small>
Old Apr 8, 2003 | 09:51 PM
88SS LS1's Avatar
Check on ebay there's some engine lifts on it right now
<img border="0" alt="[cheers]" title="" src="graemlins/gr_cheers.gif" />
Old Apr 8, 2003 | 09:58 PM
LS1swap's Avatar
Places like autozone sell the lift bracket that adjust the lifting point forward or back to adjust the angle. Hook to the heads, but put cardboard or cloth in-between the head and chain. It will keep from marring the finish if that is important to you.
Old Apr 9, 2003 | 01:16 PM
Fastlane68's Avatar
Thanks for the help. I brought up the question when I saw the item on Ebay. I decided the bracket design was too likely to damage my intake manifold so I did some more research and bought some generic lift brackets from Eastwood that I could fasten to the accessory ends of the heads. Thanks again.
