Turbo350 in 4th gen camaro
Old Nov 21, 2005 | 01:55 PM
Camaro396's Avatar
Default Turbo350 in 4th gen camaro
Does anyone on here run a turbo 350 in their small block 4th gen camaro? I need to know where to come up with a crossmember..thanks
Old Nov 21, 2005 | 02:02 PM
stevemilz's Avatar
www.BMRFABRICATION.com
Old Nov 30, 2005 | 09:56 PM
Strokinit383's Avatar
You dont have to use that one. You can just use the one you have and redrill the holes. Ive heard that the m6 crossmember is very close but this may or may not be true. If you still want to run a standard torque arm, that crossmember might be a good idea though. But if you are going to run a trak pak or similar, i would just redrill.
