Truck intake to LS6 intake
Old Dec 25, 2005 | 12:04 AM
ls1_chevelle's Avatar
Default Truck intake to LS6 intake
Can I use my fuel rails/injectors on a LS6 intake? I'd really like to keep the regulator at the rail but I'm not too sure if it will work?
Thanks guys.
-Matt
Old Dec 25, 2005 | 07:33 AM
george88gta's Avatar
Check out this link for some idea as to what you may run in to. http://www.performancetrucks.net/fo...+swap+on+a+6.0l
Also, the truck injectors use a different connector so depending on your wiring harness, you may have to change connectors. The truck injectors are a different length so you will have an issue with that. If memory serves me right, you will have to add spacers to the intake and of course, the crossover pipe will be sticking up and may interfere with other things. Some folks have successfully used Corvette fuel rails, but I believe that there is an interference at the #5 coil pack. The truck intake flows very well and produces some great torque. But it is ugly. If you are changing for looks, you may want to look around for a cover and leave the tuck intake installed.
Old Dec 26, 2005 | 09:11 AM
BLWN1's Avatar
thanks for the link
