Stiff clutch, would hydraulic help?
I have a centerforce pressure plate, disc, and bearing installed on my car. I have modified the mechanical clutch linkage to work but, the pedal is extremely stiff (I guess it’s the high performance pressure plate.) After 20 min of driving my leg is so exhausted that I can’t move the car with out burning out. Will this problem be solved with a hydraulic clutch system?
I appreciate your input.
