bcm required?
Old Jan 6, 2006 | 12:50 PM
Tyj's Avatar
Tyj
Default bcm required?
I am putting a 04 6.0 in a 72 burb and am hearing that i have to use the donor vehicles bcm to get the drive by wire to work with my pcm/ harness
is there any way around that, and if not do i need the exact bcm out of the exact donor vehicle
appreciate any help---- Ty
Old Jan 7, 2006 | 03:03 PM
Scooter70's Avatar
I'd check with Speartech but I believe that there is a separate module that controls the ETC that you need. The BCM shouldn't be necessary.
Old Jan 7, 2006 | 03:18 PM
lilicedout24's Avatar
go on ebay and look up vats bypass that is for cars with no bcm or a broken bcm its a bypass mod.this may help you its like 24 bucks
Old Jan 10, 2006 | 12:45 AM
Speartech's Avatar
9 Second Club/LS1TECH Sponsor
You need to get the TAC module for the electronic throttle to work. It's mounted on the firewall by the brake booster (also be sure and get the accel pedal and the pedal to TAC module harness).
Those ebay vats modules don't have anything to do with the electronic throttle operation, and besides that they don't even work for the vats on a truck PCM.
We carry all of the ETC parts if you can't find some of them.
__________________
91 Z28 LS2 408CI, LS9 Supercharger, LPE GT7 cam, Yank3000, 3450 raceweight.
Latest numbers: 9.71 ET, 141.42 MPH, 1.40 60' , 610 RWHP Mustang Dyno
www.speartech.com
