need help with heat .
Old Jan 10, 2006 | 08:58 PM
LS1rscamaro's Avatar
Default need help with heat .
where can i run the vaccume lines for the heater to the ls1? how can i get the heat to work with out the old ecm?
Old Jan 10, 2006 | 09:33 PM
ahowudoin's Avatar
What kind of car is it in? Don't think the ecm has anything to do with heater function. Maybe a bcm. You could tee in to a small vacuum line and use a one way check valve and maybe a canister for your heat selecter if thats the set up in your car. Really need more info please.
