Temperature Sender
Old Jan 14, 2006 | 09:49 AM
vettes1st's Avatar
Question Temperature Sender
I need a temp sender in 12mm size for the hole in the right head. This is to control a Spal PWM fan. It came with a standard 3/8" pipe which I tried to machine down to 12mm, but found there wasn't enough metal to do. Supposed to require any analog signal. It looks like standard GM two pin plug.
Old Jan 14, 2006 | 09:59 AM
ls1_chevelle's Avatar
Autometer has what your looking for.
-Matt
Old Jan 14, 2006 | 11:50 PM
pt67camarols1's Avatar
When you get the adapter from autometer or somewhere else you also need the smal autometer sender.
Old Jan 15, 2006 | 03:04 AM
nitrovette's Avatar
autobarn.com has a kit of all the sizes for $5.99 i just got it , equus makes it.it came in like 3 days.just used a autometer sender to screw right into it.
http://www.autobarn.net/eqoilpreselt.html
Old Jan 15, 2006 | 12:57 PM
Project GatTagO's Avatar
I drilled and tapped a 12mm lug bolt.
Andrew
Old Jan 16, 2006 | 12:55 PM
gogogadget's Avatar
The best place for the equus kit is the nearest trashcan. Get the smaller sender and M12 fitting from autometer.
By Brett Foote | 2026-06-04 05:00:17
