Connector Views
Old Jan 14, 2006 | 02:11 PM
ProStreetZ28's Avatar
Default Connector Views
I'm building a adapter harness for a friend of mine doing an LS1 swap, I don't have the complete factory service manual. I have part 2 of the 2000 service manual. I need the connector views for the following connectors.
C100
C101
C105
C220
C230
I've found a lot of the information I need in the manual I have & the "LS1 SWAP FAQs" thread, but I came up short on some of it. For the C220, C230, C100, C101, C102 & C105 I need the 8 digit part numbers so I can order the connector fron Delphi. If you have the connector end views and you're willing to email them to me I'd appreciate it, my email is prostreetz28@earthlink.net If you know where to find it online PLEASE let me know.
Thanks,
Jeff
Old Jan 14, 2006 | 10:01 PM
shr00m-dew's Avatar
I can't get to the part numbers and such, but here's the pinouts I typed up for my 2000 LS1 install:
C100 engine to body
A PINK 639 FUSE INJECTORS
B DK GREEN/W 459 AC COMPRESSOR RELAY
C DK GREEN 59 AC COMPRESSOR CLUTCH
D GRAY 596 5V REFERENCE
E DK BLUE 417 TPS SENSOR SIGNAL
F BROWN 86 BRAKE PEDAL OUTPUT (V6)
G PINK 239 FUSE EVAP /AUTO TRANNY
H DK BLUE 473 COOLANT FAN
J DK GREEN 335 COOLANT FAN
K BLACK 452 SENSOR RETURN
C101 engine to body
A YEL/BLK\ 625 VATS START ENABLE OUTPUT
B PINK 839 FUSE INJ 2
C BROWN 436 IDLE SPEED CONTROL MTR
D DK GRN/W 465 FUEL PUMP RELAY FEED
E PINK 439 FUSE PCM IGN
F - - -
G ORANGE 340 FUSE PCM BAT
H BLK/WHT 451 GROUND FP RELAY, GROUNDED WITH PCM
J PPL/WHT 1035 STARTER RELAY FEED (V6)
K GRAY/BLACK 1687 IGNITION RETARD SIGNAL
C105 engine to body
A PPL/WHT 1572 TCS FAILUTE LAMP (V6)
B PINK 539 FUSE,ENG SENSORS,
C BRN/WHT 1571 TCS SWITCH SIGNAL(V6)
D DK GREEN 83 CC DISENGAGE
E - - -
F WHITE 85 CC LAMP OUTPUT
G WHITE 121 TACH SIGNAL
H ORANGE 1440 FUSE AIR PUMP BYPASS
C220 engine to dash
A TAN 31 OIL PRESSURE LAMP
B GRAY 48 CLUTCH SWITCH ANTICIPATE
C PINK 539 FUSE TCC
D PURPLE 420 TCC BRAKE OUTPUT
E BLK/WHT 451 GROUND
F ORANGE/BLK 1061 SERIAL DATA (V6)
G BROWN 141 FUSE IGNITION (TURN B/U), T56 BACKUP SWITCH)
H ORANGE/BLK 434 NEUTRAL SAFTEY (AUTO)
BACKUP LAMP (T56) (LT GREEN)
J YELLOW/BLK 625 VATS RELAY OUTPUT
K DK GREEN/WHT 817 VSS 4000PPM
C230 engine to dash
A GRAY 474 5V REFERENCE
B BRN/WHT 419 SES INDICATOR
C WHITE 1310 CANISTER VENT VALVE
D TAN 800 SERIAL DATA (V6)
E DK BLUE 229 THEFT DETERENT FUELENABLE
F DK GREEN/WHT 762 AC REQUEST
G GRAY 720 SENSOR RETURN
H DK GREEN 890 FUEL TANK PRESURE
J PURPLE 1589 FUEL GAUGE SENSOR SIGNAL
K DK GREEN 1049 PCM SERIAL DATA
Hope that helps.
Kevin D.
Old Jan 15, 2006 | 09:41 AM
Kevin,
That helps a bunch!
Thanks,
Jeff
Old Jan 15, 2006 | 09:50 AM
shr00m-dew's Avatar
Stumbled on these trying to find some other info:
C100
10way FEMALE 1206-5425
10way MALE 1204-8253
C101
10way FEMALE 1206-5426
10way MALE 1206-5648
C105
10way FEMALE 1204-7937
10way MALE 1205-2454
C220
10way FEMALE 1206-4769
10way MALE 1206-4770
C230
10way FEMALE 1206-4871
10way MALE 1206-4872
Old Jan 15, 2006 | 10:33 AM
How sweet is that!
Thanks
