Will HP tuners remove vats?
Old Jan 17, 2006 | 10:27 AM
Dustin@PremierAutosports's Avatar
Default Will HP tuners remove vats?
I have to remove smog and vats for my conversion. I need to know if HP tuners will remove vats from a 2001 f body pcm.
Old Jan 17, 2006 | 11:15 AM
slow's Avatar
Yes.
Ryan
Old Jan 17, 2006 | 10:56 PM
Tiger2o69's Avatar
I tried this and it didnt work for me..
Had a viper alarm system/remote start installed and then I removed vats and it still wont remote start w/o the key in.
Old Jan 18, 2006 | 11:28 PM
LS1Cobra's Avatar
Do you have a 6 speeds manual trans or auto? I remember seeing in the manual that the brake switch has something to do with the starter relay. I will double check it tomorow. If that's the case you have to hook up another relay and bypass the brake switch when in remote start mode.
Old Jan 19, 2006 | 12:03 AM
-Joseph-'s Avatar
LSxGuy widda 9sec Mustang
In a LS1 conversion you can do that because the starter isn't controlled by the VATS module anymore. In a LS1 4th gen (even with VATS off), you have to have the resistor mod done to the wiring, or wire the starter direct to the ignition switch.
If you need VATS shut off in the PCM, TSP or any of the mail order tune places can shut it off for a reasonable price if you mail in the PCM.
Old Jan 19, 2006 | 01:21 AM
Tiger2o69's Avatar
I have it shut off by hptuners in the pcm. but since I have to wire the resister in anyway does that actually help me?
