speed-o help
Old Jan 18, 2006 | 11:16 AM
camaross82's Avatar
Default speed-o help
I am doing a ls1 swap into a 69 camaro and was wondering what options I have for hooking up a speedomiter to the t-56. And also how I can get it calibrated for different tires and gears?
Old Jan 18, 2006 | 11:24 AM
Oscar Will's Avatar
You could do what I did, I had my original (1935 Ford) speedo changed to an electronic (VDO) movement and let my PCM handle it from there. Redline Gaugeworks (http://www.redlinegaugeworks.com/) did it and it works perfectly. They do this type of stuff all the time, they do all of Jay Leno's stuff so they are very busy but I thought it was worth the time invested.
Old Jan 18, 2006 | 01:12 PM
Teetoe_Jones's Avatar
We sell a converter box from Abbott that takes the VSS signal, and in turn drives a motor hooked up to your speedo cable. You can calibrate it for different rear end ratios, and tire sizes,
Tyler
Old Jan 18, 2006 | 01:37 PM
Steve68's Avatar
I had the same question, since I have 2 5 " Autometers in the stock bezel, gee I wonder where I saw that!!!
How about the tach?? what do I do there? thanks tyler!!
