LS1 engine operation trouble
Old Jan 22, 2006 | 08:00 PM
jowell1096's Avatar
Unhappy LS1 engine operation trouble
While driving my 67 Camaro SS that has an LS1 engine with electric cooling fan, griffin radiator and manual temperature control for the fan on a day that is about 70 degrees or higher when my coolant temperature hits approximately 192 degrees or more the engine begins to die only when I come to a stop sign/light. What would cause this and what would remedy this?
Old Jan 22, 2006 | 08:26 PM
P Mack's Avatar
Your idle airflow values are probably too low for that value of coolant temperature.
Old Jan 22, 2006 | 09:55 PM
jowell1096's Avatar
Talking Thanks P Mack
I appreciate the information....what do I do to remedy this? Is there a sensor that is out or does the computer need adjusting? What tune is needed if so? Thanks for any info you might have. Jowell
Old Jan 22, 2006 | 10:13 PM
P Mack's Avatar
You could find out for sure by borrowing hptuners or efilive from someone local. It would be the computer that needs adjusting, not the sensor. The dying doesn't coincide with the fans coming on does it?
Old Jan 22, 2006 | 10:54 PM
jowell1096's Avatar
I dont think so...the computer doesnt drive or control the fan relay it is manually adjusted. The fan is on before the car starts dying. I have LS1edit to tune the computer but I have another person do the tuning...what should I tell him that involves this...I appreciate your help a bunch.
