68 Camaro Conversion what kind of gauges?
Old Jan 31, 2006 | 10:05 AM
phoenixdawg's Avatar
Default 68 Camaro Conversion what kind of gauges?
For those that have done the swap what kind of gauges did you use - mechanical or electrical? I would assume electrical, but don't have a good reason as to why?
Old Jan 31, 2006 | 12:00 PM
Steve1969LS1's Avatar
Electrical..
Why? well because they are easier to run and it requires extra parts to run a mechanical tach on a modern transmission.
modern engine = modern gauges = easier install
Old Jan 31, 2006 | 08:30 PM
67RSCamaroVette's Avatar
Autometers work well, both steve and I are using them.. Forget about using a mechanical speedo, you've got to use this mickey-mouse box that involves a motor, or switch tailhousings on the transmission. 5" Autometers fit nicely in the stock '67-68 bezel.
olly
Old Feb 8, 2006 | 02:30 PM
ItDoRun's Avatar
Did you have to do any cutting or trimming on the bezel? I'm considering the LS1 swap and am trying to do as much homework on this task as possible before I get into it.
Thanks,
Chris
