'98 Vette LS1 Swap
Old Jan 31, 2006 | 05:44 PM
OldSchoolFormula's Avatar
Default '98 Vette LS1 Swap
I found a guy parting out a '98 Corvette/M6 with 40K miles. Hed let the car go with the complete drivetrain for $4000. Now, I dont really have any desire to swap out the IRS. Can I still us ethe tranny or am I better off finding a normal ls1 f-body T56? If thats the case I may just see how much he'd get rid of the LS1 and the wiring harness and PCM for. Now, '98's are fly by wire, are they not? What can I do to fix that issue when swapping into an older car? Thanks. Im also considering maybe keeping my built 2004R. I know the bolt pattern is slightly different on the bellhousing, but otherwise can I use it with the manual PCM?
Old Feb 1, 2006 | 11:06 AM
Noones used a Vette motor in a swap?
Old Feb 1, 2006 | 11:13 AM
badjuju342's Avatar
Deranged Rat Fink
The motor will work fine but the tranny is not gonna work. Also , you'll need to buy an F-body oil pan . I can think of a few other snags you'll run into.
Old Feb 1, 2006 | 12:21 PM
55chevy's Avatar
I have a vette engine and it had already been changed to a manual throttle body. Anyway, that's not too expensive. I would be sure and get all accessories, pulleys, and accessory brackets. The vette accessory setup works a little better in most old cars since the alt is up high. The A/C compressor would probably need to be relocated. Badjuju is right about probably having to change the oil pan.
Old Feb 1, 2006 | 02:00 PM
Is there a problem with the ECM and changing to an f-body throttle body? Not sure how the TPS would differ between the two?
Old Feb 1, 2006 | 02:05 PM
Also curious, how are the motors balanced? Am I going to need a balancing job done if I keep my 2004R? I know I'd need an automatic flexplate from an LS1... but will my exisiting converter work? Same bolt pattern? How about the snout?
