Banging My Head - No Start
Old Jan 31, 2006 | 10:02 PM
crewchef's Avatar
Default Banging My Head - No Start
Finally ready to light this thing off but she's not cooperating. Cranking but no start. Done a lot of trouble shooting but can't find it. Any suggestions appreciated.
Narrowed down to injector control signal. When you crank the engine the injector will pulse twice and then nothing else. We discovered this by using a noid light that plugs into the injector connection.
Have good fuel pressure during cranking
Have good spark
Tested crank and cam sensors for good power/ground
Checked and rechecked grounds
Injectors have good constant power during cranking just not getting control signal to activate (after 2 pulses)
Using VATS bypass module and have checked wiring and all looks good there.
Disconnected other sensors to ensure things like over temp weren't shutting the fuel off.
I don't have a scan tool but have access to one and hope to get it tomorrow or Thursday.
Tony 98LS1/88 TransAm GTA
Old Jan 31, 2006 | 10:15 PM
Slo_240sx's Avatar
Definately sounds like a cam sensor problem. That scantool will come handy because if sophsticated enough it will show a yes/no on crank and cam signals. Check all of your grounds at the pcm connector, because youre not pcm isn't pulsing. Check 12v power feeds. If using the vats bypass module it should still fire and if it were to be wired incorrectly it will shut off in about 4 seconds. Try spraying it with some carb cleaner down the intake and see what it does.
-Alex
Old Feb 1, 2006 | 01:35 PM
pt67camarols1's Avatar
When i start mine first time I hooked up the fuel lines wrong and that drive me crazy. Check that out.
Old Feb 1, 2006 | 03:00 PM
Slo_240sx's Avatar
That wouldnt cause you to have no noid on the injectors. He has perfect fuel pressure.
Old Feb 2, 2006 | 07:39 PM
PLATINUMAUTO's Avatar
give dana at lt1 wiring a call.he's the man when it comes to lt1/ls1 wiring issues.
sorry,814-323-3021
Old Feb 2, 2006 | 07:45 PM
crewchef's Avatar
Platinum, thanks for the info. My problem seems to be my VATS module and I actually got it from Dana. Not sure if it was bad to begin with or if I caused it somehow but either way Dana just said no problem, new one is in the mail. Great guy to work with. I'm sending the old one back to let him play with it to see if he can figure out what the actual problem is.
Anybody needing a VATS module should give Dana a call.
I'll be sure to post a new thread when this beast fires off.
