ls2 intake swap
Old Feb 1, 2006 | 04:16 PM
woody69's Avatar
Question ls2 intake swap
Has anyone swaped out a ls6 or ls1 intakr for a ls2? Iknow the tb won't work but how about the injectors and fuel rail. Thanks Woody
Old Feb 1, 2006 | 04:24 PM
Brains's Avatar
On most combos, the LS6 makes more power.
I don't remember all the specifics, but the injector O-rings are different, the rails are different, the MAP sensor moved to the front, and obviously the TB.
Old Feb 1, 2006 | 05:33 PM
Jones'n's Avatar
I gues it has been done... check out the 3rd and 4th items down on this page.
http://currentperformance.com/Access...iring_acc.html
Old Feb 1, 2006 | 08:34 PM
98_Formula's Avatar
the 4th item down would be worth it since the injectors on the ls2 are bigger, i think 30#...
Old Feb 3, 2006 | 07:10 PM
poloz28's Avatar
you can use the ls1 injectors and rail, you need a spacer kit and new o rings, you can get them from k-tech. i have this setup
Old Apr 16, 2006 | 04:40 AM
stxdude's Avatar
Default ls2 intake swap
is that all you need in the swap or is there more items you need to replace.I know that holley makes a 4 bolt 90mm throttle body with a cable. will i feel a difference with a 6.0 ported heads and a cam or just buy an ls6 intake
Old Apr 16, 2006 | 04:47 AM
stxdude's Avatar
sorry my engine is a 6.0 with ported heads and a cam just dont know the specs on cam and poloz28 did you feel a difference when you did the swap
