LS1/T56 into 95 Camaro
Old Feb 3, 2006 | 05:03 PM
sithkhan's Avatar
Default LS1/T56 into 95 Camaro
OK - I have seen this thread and have looked at the sites posted. I also have found the site listed that had the parts chart for which parts could be kept for a particular year model of the Camaro. But, I am still uninformed.
Do I need to change the rear end out if I put the LS1/T56 in my Camaro?
Is it better for the conversion to start with a new engine/transmission or should I look for a used one?
Is the swap worth doing if you get a 40K - 50K miles engine, or is the shortened lifespan prohibative?
I am a chemist, not a gear head, and have no idea what I should expect for labor costs, as I will have to have this swap done either by someone, or with me helping.
This board has answered some of my questions, but I still have more. I love my 95, and buying another Camaro is not an option. I like mine too much to just go get another.
Thanks for reading this, and for any suggestions and advice you leave for me.
Old Feb 4, 2006 | 09:28 PM
ex-SS-ve's Avatar
rearend may not need to be swapped just change the gears to 3.42 or higher. i wouldnt be scared of a ls1 with 40-50k miles on it. they can last quite a while till you try putting higher boost 11+psi or over a 150 hp nitrous shot to it. just got wrapped up with my swap. if you got any questions or need any help pm me.
Old Feb 4, 2006 | 10:57 PM
sithkhan's Avatar
thanks for the info!
