power adder fuel line size?
Old Feb 3, 2006 | 11:31 PM
nuckifuts's Avatar
Default power adder fuel line size?
what are you guys running for fuel systems? i would like to run an intank system so i dont have to use a voltage regulator like the A1000 needs. if the high pressure 255LPH pumps have -6 outlets i dont see the point in running 1/2 inch fuel line (it can only flow as much as the greatest restriction). is a hight pressure 255 with -6 to the reg and a -4 return enough for a bolt on/cam/spray? should i step up to a Tsunami Aeromotive pump which does not need a V.R. but only has a -6 outlet? Fbodys and vettes only have -6 lines but are returnless and seem to do fine up to the 500ish RWHP mark. thanks, rich.
