Can I convert 4wd 4l80e to 2wd?
Hello, I am in the early planning stages of Converting a G-body to LSx Power. I would like to be able to run an Lq9 and 4L80E out of an Escalade. Is there a way to make the AWD trans work w/ a 2wd tailhousing? I would like to purchase a low mileage used drivetrain and install it in the car without a rebuild in order to keep costs down.
Thanks is advance.
Thanks is advance.
Originally Posted by nelson71
Do you have to tear down the trans to change the output shaft? I would probably use the custom tail housing that has the drive for a manual speedo. Does that change the situation at all?
If you're looking to do 2wd, I'd suggest you take the easy route and buy the engine and trans seperately. Buy the LQ9 out of an Escalade and a 2wd 4L80E out of a 2500 pickup.
'JustDreamin'
