rack and pinion quesiton
Old Feb 4, 2006 | 08:54 PM
blackbyrd's Avatar
Default rack and pinion quesiton
could someone tell me of the rack and pinion out of my firebird can be used when i swap in my 408 with bmr k member?
Old Feb 4, 2006 | 09:32 PM
ahowudoin's Avatar
What year bird?
Old Feb 5, 2006 | 02:29 AM
blackbyrd's Avatar
its a 2001
Old Feb 5, 2006 | 12:46 PM
Mikey 97Z M6's Avatar
Just so I'm clear here, you have a 2001 Firebird and you're installing a 408" LSX blocked engine/shortblock using a tubular K-member?
If that's correct then, why wouldn't the steering rack fit? You're keeping the Fbody pan and accessory mounting, correct? As long as the K-member was made for a factory steering rack, it should bolt right up without any issues.
Maybe I'm confused on your question though.
Mike
Old Feb 5, 2006 | 02:31 PM
blackbyrd's Avatar
no your not confused maybe i am i have heard that the racks werent the same on the 3.8 v6 and the ls1 equipped cars that is why i was asking mayve its not the rack itself but the link between it and the steering wheel that needs to change
Old Feb 5, 2006 | 03:07 PM
LOL,,, that clears it up. I didn't realize your car was a V6 to begin with. Ya, you might have to swap out the steering rack then. I'm doing an LS1 swap in my LT1 car and my rack is different from the LS1 racks. I know all the earlier (93-97) cars are different from the LS1 racks. Not sure about a late model V6 car though. Good luck.
Mike
