Starting engine after 2 years
Old Feb 11, 2006 | 12:47 PM
Uk Robert's Avatar
Default Starting engine after 2 years
I`m just about ready to start up. Having moved house and built a bigger garage, I`m virtually ready for a test firing!
However I`ve read various threads on how to do this after leaving the engine for such a long time (2yrs). Do I disconnect coils at the main connector? Take the plugs out? Wind the oil pressure up manually somewhere? How do I safely start it.
I`m also confused about the operation of the computer. The crank relearn procedure is often mentioned and I can find out about that on these boards but how do I know if I have to do it? The computer was adjusted for my application by Injection Specialiteis in Houston, Texas, so will it be ready to fire up after such a long lay off?
Also, regarding the various ground wires coming off the blue and red connections to the ECM, I`ve earthed them to the bulkhead of the car. But lots of people mention earthing them to the back of the heads......does it matter?......Thanks
Old Feb 11, 2006 | 02:33 PM
pt67camarols1's Avatar
oiling is good idea. you dont have to wory about crank re-learn if you did not change anything internaly or the sencoe to my beleive. It is like you take the power off the computer in your case. When it starts it will learn the idle.
if your bulk head/chassis grounded to the engine then should be ok
Old Feb 12, 2006 | 08:55 AM
stevieturbo's Avatar
It might be worth pulling the plugs, and disc coils or injectors and winding it voer until you have oil pressure.
Other than that, and basic oil/water checks, fire her up !!
Nothing in the ecu should have changed over time, so that should work well.
There are now a few guys in the UK who can help with re-flashing the ecu, if you think you need any changes made.
Richard Ingram, EFILive
Paul Spinks @ Wortec using HP Tuners are a couple
Old Feb 12, 2006 | 11:54 PM
GTS346's Avatar
I just disconnected both coils at there main plugs, cranked it over til there was oil pressure, plugged them back in and fired it up.
Maybe squirt some oil down the plug holes first, but as long as the engine was oiled before it was last turned off there will always be a film of oil on the cylinder walls.
Old Feb 13, 2006 | 02:26 PM
Uk Robert's Avatar
Thanks alot lads. Just got to weld a couple of exhaust flange and connect the fuel lines and away we go!
Old Feb 13, 2006 | 02:50 PM
70 LS1's Avatar
Conversion master
I just fired it up.
