Info on Quiet Exhaust
So far, I found out that I have to do some shorty headers. I live in Colorado, and we do get pipe checked at emissions, so I have to run Cats. I've seen recommendations for Magnaflow cats, so i'll probably use those.
I'm pretty sure I want to run true duals because of the sweet sound, but I'm still trying to pick out mufflers.
I figure since I'm probably never going over 400hp, I'll probably run 2.5" pipe with an H pipe.
The jeep won't have any carpet in it, and I run a soft top, so I don't want the exhaust to be too loud. I figured running true duals would be a good way to make sure I can make it nice and quiet but not too restrictive. I do still want it to have a nice mean deep sound w/o any rasp. I don't need to to be any quieter than a stock camaro, I just don't want it loud!
Can you please recommend some mufflers and advise me if any of my selections so far don't make sense.
Andrew
olly
I was able to use the stock 6.0 truck manifolds in my YJ. The driver side was fine, the passenger side had to be slightly clearanced with a torch and hammer to clear part of the motor mount that I pieced together. Took all of 5 minutes. If you get some mounts from AA, you may not need to clearance anything.
Can't offer any advice on the mufflers, I'm using cheapo turbos, not too loud.
Glenn
