exhaust pipes
Old Feb 15, 2006 | 08:06 AM
68shortstep's Avatar
Default exhaust pipes
where can i get mandrul bent pipes in all sorts of angles and u's and 90's
for making some headers?
Old Feb 15, 2006 | 08:26 AM
LS1GMCTruck's Avatar
Default pipe sections...
They actually sell do-it-yourself header kits in the mail-order & on-line performance car catalogs, such as Summit, Jeg's, etc...
Old Feb 15, 2006 | 08:34 AM
looked at summit not alot of options there. its goning in a 68 chevy truck ls1 of coarse. what are you runnin, also what year is your gmc?
Old Feb 15, 2006 | 08:41 AM
custom 68's Avatar
I think JC whitney used to carry the bulk bends to do this. we used some about 10 years ago from them to build a header for a motorcycle engine. you might check there.
Dave
also I ended up using z06 manifolds on my 68 truck. They fit very well but I built my own engine mounts so I probably positioned it differently than yours to make them fit.
Old Feb 15, 2006 | 10:50 AM
Stu Cool's Avatar
Depending on your goals for your truck, I think Sanderson has headers that will fit your appication. These are not long tube equal length units, but they have a choice of tube and collector sizes from 1.5 up to 1.75 tubes and they should be pretty good for a street runner. I am using Sandersons and while they did not have a set that fit exactly, I found a set that was close and we are moving one pipe to get them to fit right. Once we are done I will send them back to be ceramic coated. Sanderson has been excellent to work with, the headers were about $250 in plain steel, and they sent me a whole box of scrap bends and tubes to use while making the mods. Once I am done they say they will coat them for me for $110. Once we are done I will post pictures.
I seem to recall some one posting that they were using an out of the box set from Sanderson in a 60s LS1 truck.
Their web page is http://www.sandersonheaders.com/. You need to call and get their catalog because all of their LS1 headers are not shown on their web page.
good luck
Pat
Old Feb 15, 2006 | 11:10 AM
thanks......... does anyone know if normal new body style truck 5.3 headers will work?
