Master and Slave Cylinder Question
Old Mar 1, 2006 | 03:08 AM
xXxSilveradoxXx's Avatar
Default Master and Slave Cylinder Question
How close do the master and slave cylinder's bore and stroke area need to be to operate properly? If the master doesn't move enough fluid then the clutch won't disengage, but, I read that if the master cylinder moves too much fluid it will damage the throwout bearing. I know that .4415 inch is perfect (see below) but I need to know what I have to work with.
Camaro/Firebird T-56
Bore X Stroke = Area
3/4 X 1 = .4415
Old Mar 1, 2006 | 04:16 AM
1dirtyZ's Avatar
according to your calculations, shouldn't you be getting:
3/4 X 1 = 3/4 ?? (0.75)
Old Mar 1, 2006 | 04:22 AM
3/4 inch bore (circular)
Old Mar 5, 2006 | 04:21 AM
Anybody?
Old Mar 5, 2006 | 02:41 PM
stevieturbo's Avatar
try
(( bore/2 ) ^2 x Pi ) x stroke.
Pi x radius^2 x height
Pi = 3.142
radius = bore divided by 2
height = stroke
0.75/2 = 0.375
0.375 x 0.375 = 0.141 ( rounded up )
3.142 x 0.141 = 0.443
0.443 x 1" = 0.443
Old Mar 5, 2006 | 03:46 PM
Slo_240sx's Avatar
Good job ^
I got a master from Summit. Tilton's master 3/4" bore x 1" stroke. Cost me around 70 bucks. -Alex
Old Mar 6, 2006 | 04:45 PM
txoutlaw's Avatar
good ?,
I'm gonna try and use a T-Bird turbo cpe. M/C. when it gets here i'll let you guys know if this will work for the fox swaps. I've heard that it has a .75 bore but I'm not sure on the stroke yet!
