Tach Output Signal
Old Mar 4, 2006 | 12:20 PM
crewchef's Avatar
Default Tach Output Signal
Just got HPTuners and trying to get codes turned off, etc. One of the things we're trying to do is get the tach accurate. I know we need to change the output pulses but not sure what number we need to put in. Current setting is 40,000. This is for a 98 GTA. I guess we need to either double it or divide it but not sure which way to go.
Thanks!
Old Mar 4, 2006 | 10:02 PM
G-Body's Avatar
sawzall wielding director
Are you sure that you are in the tach calibration screen? The factory setting for the tach is an output of 2 pulses per rev, Your v8 tach needs 4 pulses per rev. Sounds to me like your in the VSS table, an automotic trans VSS puts out 40,000 PPM.
Old Mar 4, 2006 | 10:07 PM
crewchef's Avatar
You're right, I was confusing the two. Is there an area of HPT that allows you to change the Tach pulses?
Old Mar 5, 2006 | 08:24 AM
crewchef's Avatar
Guys at HPT taking care of it for me. Thanks!
