oil pan swaps...
Old Mar 20, 2006 | 10:09 PM
S10xGN's Avatar
Default oil pan swaps...
Hi All,
I'm swapping a truck pan onto my '03 Corvette long block and the rear corner of the pan interferes with the stock vette crank windage tray at the oil filter boss. Do you cut the vette tray, buy a truck tray, or do without?
What about the dipstick and/or tube? Seems like the oil level will be quite a bit higher with the vette 'stick. Can a longer 'stick be had?
Part numbers for the above?
Thanks!
Russ
Old Mar 20, 2006 | 10:14 PM
G-Body's Avatar
sawzall wielding director
I had a similar problem when swapping from truck stuff to f-body stuff. The best solution would be to buy a truck windage tray, but if your short on time like I was pull the tray off the motor and cut it. For the dipstick swap to a truck dipstick and tube. I don`t have part numbers but GM partsdirect would. You can use their catalog to find them, just put in the year, make, model for whatever you bought the truck pan for. http://www.gmpartsdirect.com/partsvoice/frameset.cfm
Old Mar 21, 2006 | 02:39 AM
txoutlaw's Avatar
S10xGN,
Are you in need of the truck stuff?
I have a brand NEW pan,tray and dip stick form an LQ9 crate motor. Because I need the LS1/6 pan,tray and dip stick! I also have the LQ9 water pump from this motor and need a LS1/6 pump if you are interested in a trade for those as well!
Old Mar 25, 2006 | 10:49 AM
bluecamaroz28's Avatar
Truck Oil Pan-----------12560393
Truck Oil Pump Pickup---12563961
Truck Windage Tray-----12558268
Truck Dipstick----------12558684
Truck Dipstick Tube-----12563918
GM LS1 Oil Pump to Pick-Up O-Ring--12557075
Old Mar 25, 2006 | 09:38 PM
S10xGN's Avatar
Got the pan, gasket and bolts off E-Bay, ordered the correct crankshaft windage tray, pickup tube, and dipstick from Dal. Will attempt to use my Corvette dip tube and "re-engineer" the truck dipstick to fit...
Thanks for the numbers!
Russ
Old Mar 26, 2006 | 02:44 AM
Why would a truck oil pan be needed if you swap an F-body LS1 into an S10 or any truck? What is wrong with F-body oil pan?
Old Mar 26, 2006 | 06:49 AM
blazerls1's Avatar
the truck oil pan has more clearance for the cross member.most of the depth is all the way to the rear,where the f-body has it's depth start about half way across the pan..
