AN fittings on a sumped pump Question
Old Mar 21, 2006 | 10:04 PM
Slo_240sx's Avatar
Default AN fittings on a sumped pump Question
I am in the final stages of finishing my swap. I haven't had much experience with AN/NPT fittings so the question here is, how do I connect -6AN lines to my stock sumped pump/sending unit? I will be using a Walbro 255lph pump and the lines off of the sending unit I believe are 5/16" lines. The sending unit is very familiar to a old style corvette but comes out the top instead. Do you guys just braze -6an fittings on there and just hook the lines up like that? I have 20 feet of -6 hose with fittings in the mail.The car is a 93 Nissan 240sx, access panel in the trunk. Any other advise you may have please post. Also included is a pic I got online.Thanks guys! -Alex
Old Mar 21, 2006 | 11:48 PM
fast377's Avatar
russel, earls, and aeroquip all make -an fittings. If your sending unit does not have quick disconnect style fittings you will probably have to have some -an fittings welded on. If it does have quick disconnect fittings Pure Choice Motorsports makes -an quick disconnect adaptors.
Old Mar 22, 2006 | 09:20 AM
Slo_240sx's Avatar
Will brazing work?
Old Mar 22, 2006 | 09:44 AM
digitalsolo's Avatar
I used 5/16 compression to -6 AN fittings. They're like 6 bucks each from Summit and seal great.
Old Mar 22, 2006 | 01:45 PM
Slo_240sx's Avatar
Sweet, thats what i was thinking also. I need to find a new sending unit now because mine is all rusted up...
