Steve68's Camaro.
thats good to know, but I read online about the #7 cylinder problem, so, I just trimmed the bottom of the intake, and rebent the steam vent around the LS6 vally cover, everything fits great!!!
The frame stands are on, the motor is sort of installed, it looks like with the ATS plates flipped it looks like the oil pans will be sitting on top of the frame and centerlink, not good so far, I think I can solve my problems if I buy the VA Front Runner for LS motors it mounts the A/C compressor next to the passenger side cylinder head, but it very expensive, I'm going to move some stuff around later today and see what I need to do for the propper fitment, fun!!!
http://www.kwikperf.com/lsx_alt_ps.html
so, it looks like the engine needs to come back many inches, but, today I was looking at Mark Steilows "X" and he had the same problem,
I have a PM to him on Lateral G, asking about the A/C brackets and the ATI balancer, more fab work to come!
I'm going to the beach for 3 days for my wedding, my the finance and our girls are going to get married on the beach where I used to live in CB,
I'll post a pic, I won't get a damn thing done this weekend for sure! think Zack Brown, and Buffet, I'll check back tomorrow!! I have to go to work!!!
When I get back, I'm going to remove the ATS plates and then position the motor where it needs to sit and go from there, may have to build some angle style mounts out of plate steel that meet my needs for engine setback,
So you moved the engine forward to accommodate for the A/C compressor correct? I know you dont want to run the compressor up top but with all of the other issues with the engine forward it seems you either need to run it up top or find a smaller compressor. It seems you are a solid 3 inches forward from just the standard location. Your doing all of the suspension upgrades a man could ask for but are moving the center of gravity farther from the middle of the car? I think you need to cut the firewall out set the engine back about 5 inches forget about the A/C and lets turn this car into a canyon carver.
That should get your engine in the right position. Hopefully the AC clears for you.
You may need to raise the car up so you can stab the engine at more of an angle.
Also unbolt your ac compressor mounts so you don't damage them while stabbing the engine.
