LsX engine swap into 1967 corvette
Old Mar 28, 2006 | 06:44 PM
MuTiLaToR's Avatar
Default LsX engine swap into 1967 corvette
I am very interested in swapping a ls1 or ls6 into a 67 corvette. how much work would it be to accomplish this? ill be running a c6 tranny as well. I plan on doing a set of AFR 225's custom grind cam, and 383 stroker bottom end. any help on how to go about this will be greatly appreciated. thanks - Ryan
Old Mar 29, 2006 | 07:38 AM
kossuth's Avatar
Shouldn't be too hard. If a SBC fit then the LS motor should fit with little to no modification. Street and Performance has mounts and headers that should work. As for the wiring, you can do it or have speartech or somebody work you up a kit.
Old Mar 29, 2006 | 08:47 AM
acdcgcsc's Avatar
Moderator Edit: Please don't post contact info for non-sponsors. We have paying sponsors who can supply wiring harnesses and/or mounts.
Thanks for complying in the future.
Old Mar 29, 2006 | 09:06 AM
Scooter70's Avatar
A swap into a '67 is very similar to a swap into a '70s Corvette, as they share the same chassis. You're going to encounter all of the same issues that we did. My site has some decent info and pictures and should get you started. 99.9% of the issues have been documented here on this forum, so assuming that Search works, all of the answers are out there.
What do you mean by "c6 tranny"? Corvette C6 or Ford C6? If Corvette, you're in for a lot of work. If you're up for it, there's a company called Philadelphia Motorsports that is building tube frames with C5/C6 suspension (including the transaxle and torque tube) for C2 and C3 bodies. It's a very slick setup but it's not cheap.
Old Mar 29, 2006 | 09:14 AM
dynosmith's Avatar
I am putting a LS1 in a 68 vette and I purchased the S&P mounts but they did not work for me - they are 1/2" thick aluminum and did not allow for proper motor mount alignment. I had to make mine from 1/4" stainless to acheive proper alignment. Just a heads up...
