clutch master cylinder
Old Mar 30, 2006 | 09:39 PM
mjls1's Avatar
Active Streak: 30 Days
Default clutch master cylinder
I've got a 04 ls1 from a gto with a 6 speed and trying to set up the clutch master cylinder. It's different from f-body type master cylinder. Just wondering if anyone else has dealt with the gto m/c? Or should I switch it over to f-body type m/c and use bracket that mounts behind brake m/c booster? Thanks
Old Mar 31, 2006 | 07:46 AM
Schitzo's Avatar
It would be easier to go with the already proven way...just use the F-body bracket which you can easily buy. Otherwise if your fabricating skills are good, I am sure it should not be too hard to fab a bracket for the GTO m/c
