turn key engine supply
Old Apr 1, 2006 | 07:15 PM
tbair's Avatar
Default turn key engine supply
OK guys this seems like a good buy to me but want your input.First off Im putting an ls1 in a 62 impala.www.turnkeyengine.com the 410hp. In short its a new all aluminum ls1 w/stand alone wiring harness /new ecm/complete ignition/coils/wires/plugs/75mm throttlr body/all sensors/alternator/water pump serp.belt system/jet coated shorty headers/fuel pump kit/an fitted fuel rails/fuel pump/pressure reg. flex plate k&n air filter/oil and filter.plus when I talked with them they will also put the right oil pan on for my install.also get the right addaptor for a 700r4 trans.and motor mount plates to fit my car.all new all for 7600.00 seems like a great deal to have all the right parts the first time with little hassle with the install.what do you guys think? deal or no deal.Thanks Tim ok one more thing.is the 410 hp in stock form or have they modified it? forgot to ask them.
Old Apr 1, 2006 | 08:33 PM
67RSCamaroVette's Avatar
410 crank HP is like full boltons, or stock engine with a mild cam. I think it's pretty expensive, especially considering you can get a brand new crate LS2 for $5500. If the simplicity is worth it for you, go for it. It's not a complete rip-off, but you could do better for less. I'd do longtubes for sure to get even more power and better sound, forget shorty headers, they do little for the LS1. I'm sure more people will back me up on this.
oh, and welcome to the site, you've come to the right place.
olly
Old Apr 1, 2006 | 09:27 PM
99c5vert's Avatar
Stock with full emissions controls and restricted air cleaners, you get 350 horses. I bet with just a free flow intake and exhaust, you can get close to 380-390. A little better tune, and you're almost there. 7600 seems pretty pricey - at least for me...
I bought a used setup from Lynn (hoppy28@bellsouth.net). He was great to deal with, and his after sales support has been great. You get a 6 month warranty in case something goes wrong. There are probably others who have similar deals. You'll save yourself about $3K off that price to put towards something else. .02 deposited.
Old Apr 2, 2006 | 07:58 AM
tbair's Avatar
Thanks for the input guys.Ok let me ask this if I can buy a ls2 for 5500.00 where can I get all the other stuff,wiring harness. trans adaptor.Ive looked at street & performance but the are really high priced.engine mounts? point me in the right direction.
Old Apr 3, 2006 | 09:29 PM
MEFISTUFF's Avatar
try R&d Dyno in Gardena,they have a stand alone harness and computer. Great to deal with and priced right. 310 516 1003
Old Apr 4, 2006 | 12:01 AM
Gen3Benz's Avatar
turn key engine uses delphi mefi NOT factory pcm
so you would not be able to tune for mods later on
Old Apr 4, 2006 | 12:13 AM
big stuff 3 can run it
