LS1 in Foxbody need help radiator hose
all you have to do is seat it on the condenser lower mounts (assuming you're not using AC) and use the stock mustang upper rad. hold down. the only mod you have to do it a small notch on the bottom of the pass side core support and viola!
plus you get to use the stock f-body hoses!
Think one could use the stock Mustang radiator with some different hoses?
