3rd Gen Tach - Strange Problem
Old Apr 18, 2006 | 09:39 PM
crewchef's Avatar
Default 3rd Gen Tach - Strange Problem
Tweaking and tuning on this ride. Has about 1,000 miles on it since the swap and man it's fun to drive. Anyway, on to the issue.
Doing some WOT pulls and logging data on HPT. Trying to watch the road, guages and laptop all at once which is fun in itself. Noticed that occasionally the tach looks like it just looses it's signal and drops to zero. Doesn't happen every time but when it does it's normally up at higher RPM (above 5K). It'll drop down to zero, pause and then pick back up.
Anyone ever seen this type problem before or have any guesses where to start? I've already checked the connectors I made up when wiring in the swap, everything looked good there. Also checked all the grounds that I could remember and find.
Thanks
Old Apr 19, 2006 | 12:53 AM
1dirtyZ's Avatar
on a 4th gen the first thing you look at when you get this is the grounds, particularly the one behind the driver side head.
