Can a 700R4 handle 6700 rpm ?
Old Apr 19, 2006 | 06:43 PM
NX74LS6's Avatar
Default Can a 700R4 handle 6700 rpm ?
I was talking to a buddy and he says that a 700 R4 cannot handle the extra rpms of an LS6. He said GM claims the 700 can handle 6100-6200 rpm reliably. Any one have a 700 R4 ( even with an LS1 with heads/ cam that can pull those rpms) that spins high. My 700 is built but it's already wasted 3rd & 4th- however 1st & 2nd are still good . Gonna take it apart and see what's up. Maybe a bad core(internal leak or worse crushed planetary gears ). Any help would be greatly appreciated.
Old Apr 19, 2006 | 07:25 PM
firefighter's Avatar
I'm just spit-ballin here but the 4L60e is an electronically controlled 700R4. Also most of the upgrades for the internals of a 4L60e are 700R4 derived.
Old Apr 19, 2006 | 09:53 PM
pist0lpete's Avatar
I would say shifting from 3rd to 4th at that high of an rpm on a 700r4 could be disastrous as those are the weaker gears. However 1st to 2nd and possible 2nd to 3rd should be able to handle those higher rpms. As far as outright rpms (as in a top speed run at 6700 rpms in 3rd which is 1:1 i don't see why it couldn't handle it.
Old Apr 19, 2006 | 11:46 PM
NX74LS6's Avatar
I don't think any GM cars had a 6700 rpm limit in a A4( 4L60E). Most of the a4's would turn 6000 rpm only or less. The C6 A6 spins high but that may be the 4l80e or atleast the 4l65e.
Old Apr 20, 2006 | 09:27 AM
Oscar Will's Avatar
The C6 A6 doesn't share any parts with a 4L60E, it's a completely different animal but the truck version should be very interesting for us "conversion" types. I am waiting for my first chance to check one out for my hot rod......not that my 4L60E isn't ok, I just think a six speed auto would be very cool and efficient. Another note...the A6 has no bands and servos, it has five clutches and two planetary sets, that's why they are so awesome to run up through the gears......no torque drop-off between gears, really seamless, very much like an Allison in a truck.
Old Apr 20, 2006 | 11:42 AM
Now I could be wrong but my understanding is that a 4L65e is just a 4L60e with upgraded internals. I bet if you contact one of the sponsors who rebuilds transmissions they could let you know for sure.
Old Apr 20, 2006 | 11:46 AM
Brains's Avatar
The 4l65e is a 4l60e with a 5 pinion planetary instead of a 4 pinion planetary. No significant difference there.
Old Apr 20, 2006 | 11:49 AM
'JustDreamin''s Avatar
The 700R4, 4L60, 4L60E, 4L65E, and 4L70E are all basically the same transmission. The E versions have electronically controlled valve bodies. The 65E and 70E have some quantity of upgrades to the internals (planetaries, upgraded shaft treatments, etc), but the basic design is the same.
The C6 has used two different auto transmissions. The first year they were using the 4L65E. '06 and later model years use the 6L80E, a new modular design 6 speed that will also be used in the light trucks (currently only available in the new Tahoe & Suburban).
'JustDreamin'
Old Apr 20, 2006 | 11:51 AM
92zcamaroperson's Avatar
I thought it was concluded that a 700r4 wouldnt work with an ls1?
Old Apr 20, 2006 | 12:31 PM
bczee's Avatar
If the question is can a 700r4 handle the higher RPM's.. ?
The answer is YES, if CORRECTLY built with High Performance and HD parts (Gears, Clutch, valves, etc) to handle the RPM and power range that you intend to run.
Old Apr 20, 2006 | 01:02 PM
LS-1<>57's Avatar
My 700r4 handles wot shifts routinely up to 7000 rpm ........its in my '68 first gen z-28 small block with 4.11 rear. It is a TCI race version with their lockup converter and it freakin hammers when it shifts!! I have beat the **** out of it and had no problems. Not sure of all the upgrades TCI does to their trans, but it rocks.!! Hope the 4L60E in my 57 LS1 conversion does well too!!
DK
