LS1 swap in 94 z28
Its has been stated before that its not necessary to replace everything, but having a donor / LS1 car will be cheaper in the long run.
I've replaced my:
K member,
Gas Tank,
Gauges
dash & Center console,
rear end (12 bolt)
Engine Assy
Transmission
Drive Shaft (I had a 2 piece)
Engine Accessories
Radiator
Mods to interior wiring harness
OH, and I've been busy, so it has taken me about 2 years to do this
If you don't think you'll be changing the gauges (I wanted the updated interior) then you might look for a 98 LS1 as it is the only year LS1 that had a metal tank (LT1 style) and gauges were still analog.
I went new A/C core and plubing, but others on here have only swapped compressors and used existing LT1 stuff.
Will you be swapping hood & fender? I wasn't planning on it, but someone mentioned that the LS1 lid didn't fit under the LT1 hood (unless its a fiberglass hood that can be modified).
Someone had told me that before but I just forgot about it.I wasn't planning on changing the front end. I have the ultra z hood and the intake for the hood is pretty much the same size as the ls1 lid. It sits pretty much where the ls1 lid sits. I was going to try to rig up my intake to fit the ls1 throttle body. If that doesn't work, then I might buy a ls1 lid instead or buy the ls1 K&N FIPK ( I think thats the one that replaces the lid with the oval shaped filter).
It does fit under the stock hood, he also uses the stock radiator and it works fine. I would reccomend just selling your car for what it's worth and buying an LS1 camaro or trans am.
, but it should be all set now once the tranny is rebuilt
Another thing that will make it cheaper though would be getting an ls1 out of a camaro and not a corvette ...i had to buy a lot of brackets and relocate stuff...also i cant have air-conditioning because there is no room, though i really dont need it, and i had to get a new harmonic balancer because the belts wouldnt line up once everything was moved...but overall...getting an ls1 transam or camaro would probably be cheaper...depending on wether or not you did the swap yourself or had someone do it for you.
