What a difference 4 degrees makes!
This week-end I am heading out to a friends shop to see what sort of traction bars we can design or adapt that will be the ultimate solution.This sure is a lot of fun!
Pat
I worked on a box truck that was on its 7th Allision transmission in 32,000 miles because the pinion angle wasn't right. It had 10 degrees more pinion angle than it should have. You'd have thought that it would have broken u-joints or vibrated like a paint shaker on steroids. But it didn't, it just killed transmissions.
The reason for this is that u-joints only make constant velocity when the input and output shafts are parallel (in both axes). When they are not parallel, you get a velocity ripple at speed (during every revolution, the shaft tries to speed up and slow down twice).
Glad to hear you chased down your vibration. You teeth, transmission, and wallet will appreciate it.
'JustDreamin'
I am asking because I just got done doing my tranny crossmember. The tail is sitting at 4 degrees down. This is the lowest the tranny will ever sit....that way if I ever need to change the angle I can shim it.
A vibrating car is a huge pet peeve of mine so I am doing as much as I can to ensure this thing will not vibrate.
Also where did you get the shims at?
If you are planning on keeping your leaf spring suspension, you may want to take alook at the CalTracs system from www.calvertracing.com. Their system is widely used by stock class drag racers that have to keep their stock suspension. They have a street version that I am considering. They claim they improve many handling aspects and don't impact ride to badly.
Pat
