Crank Spacers and Extended Pilot Bearings
but the T56 inputshaft is 15mm ?
ACDELCO Part # CT1082 {#12557583}
BEARING,CLU PILOT WHEN REPLACING 1999-2000 CR/SHF WITH 12559356 2001 CR/SHF, ALSO USE 12563532 SPACER, (6) 12563533 BOLTS AND IF APPLICABLE 12557583 PILOT BEARING; w/GETRAG 5-SPD MANUAL TRANSMISSION(MG5); 22.7MM ID, 43.3MM OD, 13 THK
