headers that are compatible with ls1
Old May 11, 2006 | 09:15 PM
chevrev's Avatar
Default headers that are compatible with ls1
will headers that fit on a 1984 350 small block fit an ls1?
thanks,
shad
Old May 11, 2006 | 09:22 PM
Ric's Avatar
Ric
Nope.
The good ol' 350 has siamese intake/exhaust ports, meaning two next to each other. That's why the two inside tubes on a 350 are together and the other two are at the ends of the head. LSx engines have evenly spaced ports.
Old May 11, 2006 | 09:54 PM
G-Body's Avatar
sawzall wielding director
Shorty headers are virtually useless, the 01-02 f-body manifolds flow just as well, and the 98-00 manifolds are almost as good.
I have seen people modify BBC headers to fit and 5.0L ford headers to fit since they are both closer to the design of a LSx engine. Otherwise you can just build a complete set of headers. Or see if you can fit a set of headers for a late model LS1 car in to your conversion vehicle.
Old May 12, 2006 | 08:17 AM
nitrovette's Avatar
I actually took my hooker sidepipes and reconfigured the pipes to fit ls1 flanges.
Old May 12, 2006 | 08:49 AM
82z28macdady's Avatar
i've heard alot of people cut the primaries off the exhaust manifold and fit em to hooker super comps... but that seems like a lot of work. if you're thinking about the swap into an older 4-body, most LTs and Mids dont fit anyways.. only place that makes the conversion headers is stainless works, and they charge over a grand for them
