91' LS1 Fuel fitting
Old May 19, 2006 | 02:51 AM
91sbcamaro's Avatar
Default 91' LS1 Fuel fitting
Im running a 00' F-body returnless style fuel tank, and fuel pump. Im then using my stock 91' Fuel line going to my engine. What fuel fitting do i need to connect my stock line up to the LS1 fuel lines going to the fuel rail. I believe they are the quick disconnect type, but i dont know what to search for or even what my current line is called.
Old May 19, 2006 | 03:28 AM
MattP's Avatar
bundy or GM quick disconnect. Ford quick disconnects also work. Look in the Dorman products catalog there are several fittings that are appropriate.
Old May 19, 2006 | 08:41 AM
Stu Cool's Avatar
Check the FAQ and other stickies at the top of the forum. Several fuel line options are detailed there.
Pat
