Silverado to LS1
Old May 26, 2006 | 07:37 PM
chevyspeed3's Avatar
Default Silverado to LS1
Im sure this should be a plug and play install but just want to make sure.
My friend has a 2000 5.3 auto. To go to an LS1 do we need a complete with ecm? Or will the 5.3 ecm work with a reprogram?
Also do we don't need accesories right? Should bolt up to the 4L60e I assume so Im thinking this should be an easy swap unless the block changed as far as mounts for iron to aluminum.
Sorry if its a dumb question but couldn't find a definite answer on a search.
Old May 26, 2006 | 07:46 PM
stocks10's Avatar
everything will bolt up. All you will need to do is tune it
Old May 26, 2006 | 07:49 PM
Thanks for the quick reply.
Can we use the truck ECM?
Old May 26, 2006 | 07:56 PM
stocks10's Avatar
yup, it should work just fine.
Old May 26, 2006 | 09:18 PM
Out1aw's Avatar
Yes, it is a plug and play install. Many people over on performancetrucks.net (a sister site to LS1tech) have done the conversion and can probably help you out with any questions.
