is the necessary to run stuff the same on a 01 5.3 harness to ls1
Old May 28, 2006 | 11:15 AM
12thstreetjunkman's Avatar
Default is the necessary to run stuff the same on a 01 5.3 harness to ls1
I am helping a friend put an 01 5.3 in and 86 c-10. I have modded a harness myself for an ls1/rx-7. Are the pinouts from the pcm the same as what they were from the ls1 harness. I still have all the pinouts diagrams I used for it, and it looks like all the colors are the same for the same pin #'s. He is going to run a th350, so really all I think I will need is injectors, coils, crank and cam trigger, primary o2's, knock, and the intake/tb sensors. Would it be safe to say they are in the same location as they were on the ls1 harness and I can just gut the rest. Thanks for looking.
Old May 29, 2006 | 11:57 PM
G-Body's Avatar
sawzall wielding director
I am not sure if they are the same, I know some of the pins are different, but those may be for truck only stuff. But just check the FAQ sticky, there are pinout in there for an 01 truck 5.3L.
