LS1 on engine stand
Old May 30, 2006 | 11:06 PM
ndghotroder's Avatar
Default LS1 on engine stand
Built alot of cast iron blocks on engine stands but this is my first aluminum. should I get an engine cart or will it hold up on an engine stand by the 4 bell housing bolts? Got to tear it down to paint for install into 67 malibu with 6 speed gear box.
Old May 30, 2006 | 11:23 PM
JeepinBash's Avatar
when i bought my motor (LS1) it had been on an engine stand for almost a year with all the brackets ,accessories and full of oil. i also have it on a stand right now. doesn't seem to affect it at all.
Old May 30, 2006 | 11:24 PM
pist0lpete's Avatar
SHouldn't have any problem with an engine stand just make sure and get as many threads into the block as you can. Good luck with your project I will keep my eye on it since I am doing a 67 Chevelle myself.
Old May 31, 2006 | 09:54 AM
fast377's Avatar
It should be fine. My motor has also been on a stand for a while. About 3 or 4 years!!
Old May 31, 2006 | 10:26 AM
MrDude_1's Avatar
as long as your bolts are a reasonable length, theres no diff.
Old May 31, 2006 | 09:28 PM
Thanks, I was fearing the worst and wanted to make sure it wouldnt happen.
