fuel tank return line
Old Jun 10, 2006 | 03:51 PM
99c5vert's Avatar
Default fuel tank return line
I just bought an RCI tank, which has the return and supply fittings on top.
I'm going to add a fitting at the bottom for the supply fitting.
Is there any problem with having the return line located at the bottom of the tank too?
Old Jun 10, 2006 | 05:53 PM
leonpiper69's Avatar
should not be a problem, i had a typical fuel cell in my drag car and it only had 2 fittings at bottom and one at top fro vent. and it worked fine. this was on a carbed car at @8psi so presure should noit be an issue, if your worried about fuel not flowing back into the cell.
Old Jun 10, 2006 | 06:26 PM
99c5vert's Avatar
Awesome, thanks... that makes my plumbing much cleaner
