bellhousing boss ?????????
Old Jun 15, 2006 | 06:41 PM
kingb's Avatar
Default bellhousing boss ?????????
i am installing a 5.3 in my 85chevy truck. 5.3 is mating to a turbo 350. i have noticed that the 3 o'clock belhousing boss has never been drilled or tapped. any one else run into this
Old Jun 15, 2006 | 10:55 PM
redaddiction's Avatar
You just dont put a bolt there has been done before. I guess if you wanted there should be enough material to drill and tap but alot of unecessary work.
Old Jun 15, 2006 | 11:25 PM
67RSCamaroVette's Avatar
I'd just leave it out, rather than risking punching through #8 cylinder.
Old Jun 15, 2006 | 11:40 PM
G-Body's Avatar
sawzall wielding director
If the hole you are talking about is the one right behind the #8 cyl then you cannot drill it, GM determined that the bolt in that position was not needed and they left it out. If you drill it you WILL hit piston, do not try to drill it.
