has anyone tried the chevelle or firstgen fbody headers on a thirdgen?
heh, i was just looking around.. they seem ALOT closer to fitting then any of the 4thgen/C5/C6 headers.... they look like they might fit with a tubular Kmember thirdgen..
I personally dont know anything about how a 1st gen header works, but if they tilt inwards, it might work.
exactly.
his attached pic highlights the problem:
look at the bottom of that header.. notice how the collector is pointing outward? now most normal car headers point straight back, parallel to the transmission.. but the 4thgens have it kicked out to the side so that the Ypipe can go out and around....
the real problem isnt clearing things up top, its that bottom collector hitting the subframe and suspension of the car from undernieth.
i was just thinking.. wait a sec... on chevelles and firstgens, they have a "normal" exhaust that goes thru the trans tunnel... so these headers might work.
if you could tell me how far away that 3" exit tube is from the T56 on each side, and how far back it is, i could use that measurement on my car and tell if the collector will work.
i only have two tight spots... the collector exit location we're talking about now, and the drivers side near the brake booster... and i expect your brake booster is in about the same location, so that should clear just fine...
What trans are you planning on running?
on a side note... i found something intresting.
anyone else ever notice how much the stainless works 1stgen camaro swap headers look like the stainless works "3rdgen swap" headers from hawks?? i mean, while they are slightly diffrent, they're almost identical..... too bad the entire point of this is that i DONT want to spend $800 on a set of headers.. lol.
dude, how did you make the picture come up like that? i can only figure out the manage attachment ones???????
[IMG]Put the web address for the file in here.[/IMG] They must be online. Right click the image and copy location, then paste it between the tags.
- attach the pic like you normally do, and post your post up.
- now click your attached pic so you can see it fullsize.
- at the top of the browser, is the address of the pic... copy that entire line. ( if you dont know how to copy, just ask)
- go back to your post
- click edit
- put the cursor where you want the pic to be.
- paste in the address you copied earlier.
- highlight the address you copied, and press the "picture" button... it looks like a yellow box with a mountian in it.
that should be it... once you get the hang of it, it'll only take a couple seconds to do.
They end right before where the trans gets larger. A little below and forward of the first solenoid on the drivers side of the trans. Kind of hard to explain, but I didn't have time for a pic.
In this pic right where the strap is going around the trans is where I am trying to describe.
Let me know if this helps or needs more description/measurements.
